Problem with cookie and JS!
Could anyone see whats wrong, errormessage is ‘SRUsrNam’ is null or not an objekt.
Kind regards
Fredrik
Subject: Problem with cookie and JS!
Are you sure the field is on the form (Form.SRUsrNam) when you look at the html source code, and has the same name (case sensitive)??
Subject: RE: Problem with cookie and JS!
Yes 100% sure
