Problem with ComposeDocument
Hello, I create the foillowing Document-Action and get a Problem.
This script copy some adress information from my databasedocuments to a notes-adressbook.
When I use the regular adressbook (Names.nsf) all work fine without any problem,
but when I use a new adressbook (secound adressbook), created from the pernames.ntf template, the script run without problems as long as the new adressbook opened the first time after the copy.
When I use the Actionbutton after the new adressdatabase was open notes goes to a ‘spinloop’
and the only way to stop this, kill the notes prozesses.
Add information, when I open the new adressbook after the copy. the About Document of this DB
will be displayed the first time.
I try the script in a Agent, too → same problem…
any hints are welcome.
Regards Lars
    Dim sworkspace As New NotesUIWorkspace
    Dim tworkspace As New NotesUIWorkspace
    Dim suidoc As NotesUIDocument
    Dim tuidoc As NotesUIDocument
    Dim tdb As NotesDatabase
    Dim kunde As String
    Dim kundelang As String
    Dim stra As String
    Dim plz As String
    Dim ort As String
    Dim phone As String
    Dim dirfn As String
    Dim answer As Integer
    Dim inputstring As String
    Set suidoc = sworkspace.CurrentDocument
    kunde = suidoc.FieldGetText( "Adres" )
    kunde = Replace(kunde,"ß","ss")
    kunde = Replace(kunde,"ä","ae")
    kunde = Replace(kunde,"ü","ue")
    kunde = Replace(kunde,"ö","oe")
    kundelang = suidoc.FieldGetText( "Adres_1" )
    kundelang = Replace(kundelang,"ß","ss")
    kundelang = Replace(kundelang,"ä","ae")
    kundelang = Replace(kundelang,"ü","ue")
    kundelang = Replace(kundelang,"ö","oe")
    stra = suidoc.FieldGetText( "Adres_2" )
    stra = Replace(stra,"ß","ss")
    stra = Replace(stra,"ä","ae")
    stra = Replace(stra,"ü","ue")
    stra = Replace(stra,"ö","oe")
    plz  = suidoc.FieldGetText( "Adres_3" )
    ort = suidoc.FieldGetText( "Adres_4" )
    ort = Replace(ort,"ß","ss")
    ort = Replace(ort,"ä","a")
    ort = Replace(ort,"ü","u")
    ort = Replace(ort,"ö","o")
    phone = suidoc.FieldGetText( "Adres_5" )
    inputstring = "Please Enter the Filename of the used Adressbook w/o .NSF (e.g. FFATAdres)"_
    & Chr$(13) & "If you use the Primary Notes Adresbook enter 'NAMES' w/o .NSF,  "_
    & Chr$(13) & "but it's recommended to use a separat adressbook. " & Chr$(13) & " "
    dirfn = Inputbox(inputstring,"Get Adressdatabase")
    If Ucase$(dirfn) = "NAMES" Then
            answer% = Messagebox("... Adress BookTitle   <-   Is this the correct DB?", 4, "Database Name")
            If answer <> 6 Then Goto ende
            Set tuidoc = tworkspace.ComposeDocument( "", "names", "Person" )
    Else
            Dim dbchk As New NotesDatabase("","..\notes\data\"& dirfn)
            If dbchk.Title= "" Then Goto notvalid
            answer% = Messagebox(dbchk.Title & " <-   Is this the correct DB?", 4, "Database Name")
            Set tuidoc = tworkspace.ComposeDocument( "", "..\notes\data\"&dirfn, "Person",,False )
    tuidoc.ExpandAllSections
    tuidoc.FieldSetText "LastName", kunde
    tuidoc.FieldSetText "CompanyName", kundelang
    tuidoc.FieldSetText "OfficeStreetAddress", stra
    tuidoc.FieldSetText "OfficeZip", plz
    tuidoc.FieldSetText "OfficeCity", ort
    tuidoc.FieldSetText "OfficePhoneNumber",phone
    tuidoc.Refresh
    tuidoc.Save
    tuidoc.Close(True)
    Messagebox "Finished creating the document!"
    Goto ende
notvalid:
    Messagebox" you enter a not valid Database",16,"Information"
ende:
Subject: Problem with ComposeDocument
Hello,thanks a lot for the help.
The problem was fixed with
Dim fpath As String
fpath = session.GetEnvironmentString(“Directory”,True)
I use also
Dim vari As Variant
vari = sWorkspace.Prompt(13,“Get”,“Database”)
to get the Choose Database Popup
Now it is very comfortable.
Regards Lars
instead of using "…\notes\data"
try this
fpath = session.Environment(“Directory”) ’ check the exact syntax
fpath= fpath &"" & [user entry]
Hello lars,
I would recommend that you use the Prompt method from the NotesUIWorkspace class to get the server and path for the addressbook database, and then use the Notes back-end classes to “compose” your document (since you do not allow the user to do any editing to the document before you save and close it).
From Designer Help:
variant = notesUIWorkspace.Prompt( type%, title$, prompt$ [, default ] [, values ] )
Parameters
type%
Constant. Indicates the type of dialog box that you want to display. May be any of the following:
PROMPT_CHOOSEDATABASE (13)
Note The constant name PROMPT_CHOOSEDATABASE is not implemented in Release 6.0 but the literal value 13 can be used instead.
PROMPT_OK (1)
PROMPT_OKCANCELCOMBO (5)
PROMPT_OKCANCELEDIT (3)
PROMPT_OKCANCELEDITCOMBO (6)
PROMPT_OKCANCELLIST (4)
PROMPT_OKCANCELLISTMULT (7)
PROMPT_PASSWORD (10)
PROMPT_YESNO (2)
PROMPT_YESNOCANCEL (11)
And then instead of:
Set tuidoc = tworkspace.ComposeDocument( “”, "…\notes\data"&dirfn, “Person”,False )
'etc…
do:
Set tdoc = dbchk.CreateDocument
tdoc.ReplaceItemValue “Form”, “Person”
tdoc.ReplaceItemValue “LastName”, kunde
'etc…
tdoc.ComputeWithForm True, False
tdoc.Save True, False
