Problem with chars as à,ò,è,ì
Hi all,
I create a contact using iNotes Domino Web Access.
I insert firstname = “marì”.
In the contact detail window I see the correct firstname but in the contact list view I see
“marO(” or somthing like that.
can anyone tell me how to solve this problem
thanks in adevance
nadia
Subject: problem with chars as à,ò,è,ì
I think it’s related with Inotes 6.5.1. It’s solved in 6.5.4. I’m gonna check and get back to you,
JYR
Subject: RE: problem with chars as à,ò,è,ì
thanks for reply.
I’ll wait your check. In the same time I can install and try the 6.5.4 version on the stage machine.
nadia
