Problem with change Inputbox for OpenFileDialog
I have kind question for all, I use „Inputbox” in below pressed code to take name of file for Import from excel, I want change “Inputbox” to “OpenFileDialog” But I haven’t idea how do that. Pleas can you help me? I try use:xlFilename = notesUIWorkspace.OpenFileDialog(False, “Select file for Import”, “.xls”)
code but it don’t work.
Sub Click(Source As Button)
On Error Goto errmsg
Dim count As Double
Dim counter As Double
count = 0
counter = 0
Set dbCurr = session.CurrentDatabase
Dim xlFilename As String
'// (I try it but don't work) xlFilename = notesUIWorkspace.OpenFileDialog(False, "Select file for Import", ".xls")
xlFilename = Inputbox ( "Proszę podac ścieżkę do pliku wejsciowego excel Przykładowo c:\excel.xls", "Wybór ścieżki pliku do importu" , "" )
If xlFilename = "" Then
	Exit Sub
Dim One As String
Dim row As Integer
Dim written As Integer
'// We connect to Excel and open the file. Then start pulling over the records.
Dim Excel As Variant
Dim xlWorkbook As Variant
Dim xlSheet As Variant
Print "Connecting to Excel..."
Set Excel = CreateObject( "Excel.Application" )
Excel.Visible = False '// Don't display the Excel window
Print "Opening " & xlFilename & "..."
Excel.Workbooks.Open xlFilename '// Open the Excel file
Set xlWorkbook = Excel.ActiveWorkbook
Set xlSheet = xlWorkbook.ActiveSheet
Print "Uruchamianie importu z pliku excel......."
Dim NumberOfRows As Long
NumberOfRows = xlSheet.UsedRange.Rows.Count
count = xlSheet.UsedRange.Rows.Count
Dim RowPointer As Long
Dim i As Integer
Dim view As NotesView
Set view = dbCurr.GetView ( "a1" )
If view Is Nothing Then
	Exit Sub
Call view.Refresh
Dim antwort As Integer
antwort = Msgbox ( "Będziesz importwał" & Wierszy & " zapisanych w bazie danych. Kontynuować?" , 4 , "Start import?" )
If antwort <> 6 Then
	Exit Sub
Dim schluessel As String
Dim doc As NotesDocument
Dim summe As Double
For RowPointer = 1 To NumberOfRows
	schluessel = xlSheet.Cells( RowPointer , 1 ).Value
	Set doc = view.GetDocumentByKey ( schluessel , True )
	If doc Is Nothing Then
		Set doc = dbCurr.CreateDocument
		doc.Form = "test_excel"
		doc.Proc_ID= xlSheet.Cells( RowPointer , 1 ).Value
		doc.Proc_nazw= xlSheet.Cells( RowPointer , 2 ).Value
		doc.Proc_wag= xlSheet.Cells( RowPointer , 3 ).Value
		doc.Proc_ID_zas= xlSheet.Cells( RowPointer , 4 ).Value
		doc.Proc_nazw_zas= xlSheet.Cells( RowPointer , 5 ).Value
		doc.Proc_cel= xlSheet.Cells( RowPointer , 6 ).Value
		doc.Proc_cel_1= xlSheet.Cells( RowPointer , 7 ).Value
		doc.Proc_general_omow= xlSheet.Cells( RowPointer , 8 ).Value
		doc.Proc_general_zakres= xlSheet.Cells( RowPointer , 9 ).Value
		doc.Proc_general_wdroz= xlSheet.Cells( RowPointer , 10 ).Value
		doc.Proc_general_admin= xlSheet.Cells( RowPointer , 11 ).Value
		doc.Proc_general_zarzad= xlSheet.Cells( RowPointer , 12 ).Value
		doc.Proc_general_zalec= xlSheet.Cells( RowPointer , 13 ).Value
		doc.Proc_general_szkol= xlSheet.Cells( RowPointer , 14 ).Value
		doc.Proc_general_kontrola= xlSheet.Cells( RowPointer , 15 ).Value
		doc.Proc_uwagi_ogolne= xlSheet.Cells( RowPointer , 16 ).Value
		counter = counter + 1
		Call doc.Save ( True , True )
	Print RowPointer & " przetwarzanych rekordów, " & counter & " stworzono dokumentów!"
Next
Print "Rozłącznie z excelem..........."
xlWorkbook.Close False '// Close the Excel file without saving (we made no changes)
Excel.Quit '// Close Excel
Set Excel = Nothing '// Free the memory that we'd used
Print " " '// Clear the status line
Msgbox RowPointer & " przetwarzanych rekordów,, " & counter & " stworzono dokumentów!"
Call ws.ViewRefresh
Exit Sub
errmsg:
Msgbox ( "Błąd importu " & Error & " w lini numer " & Erl )
Msgbox "Linie w pliku excel " & RowPointer
Exit Sub
Subject: Problem with change Inputbox for OpenFileDialog.
OpenFileDialog returns an array, not a string, even if you have the multiple file setting set to False. So declare xFileName as a Variant to catch the array, then use xFileName(0) to get the selected filename.
Tahank you very much, I used your advice and it work’s.
