Hello everyone,
we have a little issue with CC.
at some pc when people receive a mail and they reply to that mail with the button “reply to all” then
with the new mail their own name is also in the CC.
with other people we dont have that problem.
can you point me to the right direction for a solution
thanks in advance
Tom
Subject: problem with CC
Hello Rodrigo,
thanks for your help. The problem is solved
Best regards
Tom
Hello Rodrigo,
Thanks for th information.
I will try it out when i’m back at the office (next Monday)
When it works then I will close this topic.
Best regards
Tom
Subject: Re: problem with CC
Hello Tom!
In fact, this issue was reported to Quality Engineering as SPR# CYII4V8UT8; however, it was determined to not be a software problem.
On TechNote below there are additional information regarding the issue:
Title: ‘Reply to All’ message includes sender’s name in the ‘To’ and/or ‘cc’ fields
Doc #: 1102993
URL: http://www.ibm.com/support/docview.wss?uid=swg21102993 http://www.ibm.com/support/docview.wss?uid=swg21102993
Best Reagrds!
Rodrigo
