Problem with administration console (Help Me Please)
Whenever I try to enable the “live” server console for any other server than the administration server, I get about 5-10 lines of live code before it freezes. If I restart Notes, not just the adminsitration client, it continues to do the same thing. Obviously, this is very annoying. Has anyone else encountered this problem? Again it’s every server in our organization other than the administration server.
Thanks a lot
Subject: Problem with administration console (Help Me Please)
Antonio,
One reason the Domino console will hang and stop sending messages to the screen is if you have inadvertantly enabled the edit options for the console window.
Verify that the options are unchecked by clicking the console window’s upper left corner, then choosing Properties. Under “Edit Options” there should NOT be any checkmarks for either “QuickEdit Mode” or “Insert Mode”.
Make sure you communicate this to all your operators, Notes administrators, and Notes developers.
Ken
