Subject: RE: *It used to work that they were added if you created a db with that design. Does that not work now?
Sorry - just assumed it worked the same way as refreshing/replacing the design of a database and that documents were not affected. Just tested creating a new database and it did include the documents from the template. (I’m running 6.5)
Sorry, some more detail i have now.
When i make a new database based on that database it’s working fine , but when i register a new user with the mail database template based on the new design it’s not working. Then i am missing the documents in the calendar.
