Problem while transferring values b/w fields in web
Hello Everyone,
I have an web form where i call an agent to compute some value and put it back to a field in the web form.
The agent work’s with normal text values like “some text” and numeric values.
But if i compose something like:
dim strXML as String
strXML = |<?xml version="1.0" encoding="utf-8"?>
           <movie>
                <name></name>
                <year></year>
           </movie>
and then try to put the string value to a field in the web form, it fail’s miserably! The browser throws a syntax error saying “expected ;” I doub’t whether this has something to do with the string syntax (as it is in xml format). I’m stucked up on this.
Help on this greatly appreciated,
Thanks,
Jason
Subject: Problem while transferring values b/w fields in web
Did you set the content-type of the response?
