Hi All, I want to create directory in AIX environment by using Lotus Script, i can use mkdir command, the problem is the directory is dynamic, if i use midir /tmp/somu/lotus the directory is not created, but if i go one by one like first i craete mkdir /tmp chmod 777 tmp,mkdir /tmp/somu, chmod 777 tmp/somu , mkdir /tmp/somu/lotus, chmod 777 /tmp/somu/lotus it is working fine.
localpath = “/tmp/somu/lotus”
this command will solve my problem
mkdir -m 777 -p " + localpath
but i don’t know how to write it in lotus script.if i write it it is giving error, i used the following script
pearl2 = Freefile()
Open pearl2 For Output As #2
Write #2, "mkdir -m 777 -p " + localpath
Close #2
i = Shell(pearl2)
If i = 32 Then
Kill pearl2
Print “Folder Successfully created”
pls advice me.
regds
soma
