Set Picklist = workspace.PickListCollection(PICKLIST_CUSTOM,True,CurDb.server,CurDb.filepath,COMLINESTR, “commitmentLineStr”, “selectCommitmentLineToPayStr”,“”)
I got “Cannot execute specific command” LotusNotes message with the Picklist window openning, it is very annoying. I used debug, but I can not find any problem on the codes, just that message popup when picklist window openning.
The thing is I need the prompt window for user to input data and then use it on the second picklist window. But if I hardcode the flag1 return data which do not use prompt, no problems. But I need prompt to accept user input.
It seems Prompt can not be used with picklist window?
Subject: Problem when using Prompt and Picklistcollection, Help please!
I don’t see how you have used Flag1 in calling the PickListCollection. But if you can hard code a value for Flag1 but can not get it from the prompt then this should be the first clue that perhaps the value the Prompt passes to Flag1 one is wrong. What is the Data Type for Flag1? Is it defined explicitly Dim Flag1 as String? What do you do with the value for Flag1?
Subject: RE: Problem when using Prompt and Picklistcollection, Help please!
Hi Bill,thanks a lot for your response so quick.
there are some lines of codes between flag1 and picklist, but let’s make is simple, I have created a simple following codes with a click button which can simulate that problem.
CurDb.title = “ITEC 2005”
So Temp(0)=“2005”
Temp(1)="2004"
You will get that error after you click button to let the Prompt popup first, then click OK, then the error message will popup with the picklist window.
And ideas?
Sub Click(Source As Button)
Dim PrepayInvStr1 As String
Dim PrepayInvStr2 As String
Dim temp(4)
Dim CurDb As notesdatabase
Dim flag1 As Integer
Dim Picklist As notesdocumentcollection
Set CurDb=session.CurrentDatabase
Dim COMLINESTR As String
COMLINESTR="AccruedInvoices"
temp(0)=Right(CurDb.title,4)
temp(1) =Cstr(Cint(Right(CurDb.title,4)) -1)
flag1 = workspace.Prompt( PROMPT_OKCANCELEDITCOMBO, "test1", "PrepayInvStr2", temp(0) , temp )
Set Picklist = workspace.PickListCollection(PICKLIST_CUSTOM,True,CurDb.server,CurDb.filepath,COMLINESTR, "commitmentLineStr", "selectCommitmentLineToPayStr","")
Hi Stephen,Thank you so much for the help,
Yes, you are right, the problem is the AccruedInvoices view.
I have formula “@Command([ViewExpandAll])” in the queryopen event of that view.
It is OK after I remove that formula.
But the thing is that the view with that formula in the picklist window has been used for 3 years without problem. just I want to add more codes with the prompt, the problem happened. Weird.
