Problem when starting Domino 6.5.1 on iSeries
I become crazy. I have installed a domino 6.5.1 server on iSeries. It worked well so I decided directly to install Sametime on it…
Now, when I start domino, it’s ok but if I load the http task, no more access is possible. It seems that any port is freezed !!
I disabled sametime, I stopped the iSeries http task, I changed the domino http port number… Nothing helped… The server is freezing and we cannot access anymore the iSeries except with the clientAccess currently running…
Now, I have this error message in my log → the domino server job QJVAEXEC/QNOTES/527016 has encountered an unexpected error.
The title of the error is LTN099C.
Has anybody any idea of what it should be ?? Please help…
Thanks very much for any answer !
Subject: Problem when starting Domino 6.5.1 on iSeries
Did you install the IF1 prior to installing Sametime? That’s necessary if you’re going to install Sametime or Quickplace. I think you’ll need to backoff the Sametime install prior to installing the IF1 PTF and then install Sametime again.
