Problem when setting mail rule via WEB
Hi all,
There is a problem with mail template.
Using Notes client, mail rule dialogue offers option “send copy to”.
Using WEB browser this option is not available.
To fix the problem I have made these changes:
  1. Insert choice in Form (wRulesDlg) / Field ActionValues - for example:
“move to folder”:“copy to folder”:“send copy to”:“set expire date to”:“change importance to”:“delete”
  1. Insert choice code (“|B”) in Form (wRulesDlg) / Field Action - for example:
ActionValues+“|1”:“|4”:“|B”:“|A”:“|2”:“|3”
  1. Insert next line in Script Library Rules / Procedure ButtonOKWeb some where before calling the ProcessAction for example after the line Set view = db.getview(“Rules”):
copyto = note.GetItemValue(“CopyTo_Address”)
Regards,
Anton.Apostolov@SkalaSoft.com
