Problem when save document
Hi everybody,
Here is my problem:
I’ve got one main form in my project (who allows to store all the data of the database), and a second form that i used like a configuration page of my application.
When i create my configuration page(if it’s the first use, and it doesn’t exist) and save it in a particular folder (folderconfig), that automaticaly create a empty document (main form) on the general folder where are store all my documents…
How i can make for to select the form i need
when i create a new document and save it without create a general empty document ???
here an exemple of the code :
set newdoc = new Notesdocument(DB)
newdoc.label1 =“…”
newdoc.label2 =“…”
call ws.dialogbox(“form_config”,…,newdoc,true)
call newdoc.PutinFolder(“folderconfig”)
call newdoc.save(true,true)
if someone have a suggestion about this problem
thanks to say me …
Subject: problem when save document
you have to set Form property of your new Document:
newdoc.Form = “AliasOfTheFormIWant”
… then you proceed with your code.
Hope it helped.
