hcl-bot
1
Hi,we have a client that upgraded to Snow Leopard and after uninstalling the 8.5.0 client and installing the 8.5.1 client, this error appears:
"The installation failed.
The following step failed: run postflight script for Expeditor framework. Contact the software manufacturer for asistance."
I know that 8.5.1 is still not supported on Snow Leopard, but is there a way to use it meanwhile?
Many thanks
Oliver
hcl-bot
2
Subject: Try again on 10.6.2
Uninstall it by Uninstaller and re-install again. If still fail, please post your install log here, thank you
hcl-bot
3
Subject: Solved
I had to delete the Lotus Notes Data and the files in /user/library/Preferences:Lotus Notes
com.ibm…
eclipse…
desktop6.ndk
HTH
hcl-bot
4
Subject: Where is the install log?
OK, no problem, but where is the install log?
Many thanks
Oliver
