Problem when configuring Notes client v6.5 on a MacIntosh G5
Hi
I have a problem when I want to configure a Notes 6.5 client on a MaciNTOSH G5 with Mac OSX 10.3. When I launch the client I have the following message:
Unable to load workspace file: desktop6.ndk
And impossible to load the client. I tried to re-install the client with another Notes 6.03 release that’s the same thing. I re-installed the OS and over the client but without result.
Does anyone have a solution to this ?
Thx
Pierrick
Subject: Problem when configuring Notes client v6.5 on a MacIntosh G5
Most of the configuration and launch errors of Notes are caused from “wrong” file permissions.
Please check all of the files in your Notes Data directory (especially all *.nsf, *.ndk, *.box) to have read AND write permissions for you user account.
Regards, Thomas
