Hello,I have setup SSL like in this tutorial : http://www-1.ibm.com/support/docview.wss?rs=463&context=SSKTMJ&context=SSKTWP&q1=Create+AND+SSL+AND+Certificate&uid=swg21114148&loc=en_US&cs=utf-8&lang=en
When I try webmail in http, I have no problem.
If I try access webmail in https, after i have put my user name and pasword, the system ask me again and again to enter my name and password.
Why dont you first test it by creating a self certified key ring and certificate. Select option 3 to create the key which by default is selfcert.kyr and you need to do this on the domino server itself so that the key is created in the domino servers data directory.
Next change the SSL key file name in the server documents Ports → Internet Ports tab to selfcert.kyr. (or the keyfile name you gave it in finishing option 3) Restart the server and test if it works.
