Problem - upgreding client 5.08 to 6.0 folders still in r5.08 format
Hello :slight_smile:
I am having a strange problem with R6 client .
When i replace design to R6 everything is fine.
but … the folders that i created in R5 ,when i open them insude the format is R5 and giving a “UICOPYINTONEWDOCUMENT” message…
Have anyone an idea ???
Thanx
Subject: Problem - upgreding client 5.08 to 6.0 folders still in r5.08 format
Strange that you get a error message, but the behaviour is quite normal.
Go to:
“Actions - Other - Upgrade Folder Design”
This should upgrade your folders based on your inbox format, I guess.
I would also recomment you to take a look at OpenNTF’s mailtemplate for Domino 6. For more information, take a look at http://www.openntf.org
Regards,
Rune Carlsen
Founder Dominozone
http://www.dominozone.net
Subject: RE: Problem - upgreding client 5.08 to 6.0 folders still in r5.08 format
Thank you Rune :slight_smile:
It works !!! now it is Ok …
i wonder why it did not do that while upgreding…
thnks anyway
Simantov
