Problem transfering Button LS code to Agent
Dear All,
I have a code that transfers mail body contents to another database creating each document for each mail.
The code is working with the button but when i add it at a agent just doesn’t work.
Dim Session As New NotesSession
Dim db As NotesDatabase
Dim db2 As New NotesDatabase( "Server", "xxx.nsf" )
Dim doc As NotesDocument
Dim doc2 As NotesDocument
Dim rti As NotesRichTextItem
Dim rtnav As NotesRichTextNavigator
Dim rtrange As NotesRichTextRange
Dim iCount As Integer
Dim vSplit As Variant
Dim NewDoc As NotesDocument
Dim collection As NotesDocumentCollection
Set collection = db.UnprocessedDocuments
Set doc = collection.GetFirstDocument()
While Not(doc Is Nothing)
'Set doc = ws.CurrentDocument.Document
	Set rti = doc.GetFirstItem("Body")
	Set rtnav = rti.CreateNavigator
	Set rtrange = rti.CreateRange
	Set session = New NotesSession
	Set db = Session.CurrentDatabase
	Set Newdoc = New NotesDocument( db )
	Set doc2 = New NotesDocument ( db2 )
	doc2.Form = "MainForm"
	Newdoc.Form = "Memo"
	If rtnav.FindFirstElement(RTELEM_TYPE_TEXTRUN) Then
		Do
			iCount = iCount + 1
			Call rtrange.SetBegin(rtnav)
			vSplit = Split(rtrange.TextRun, Chr(9))
			If icount = 2 Then
				doc2.Title = vSplit(Ubound(vSplit))
                etc........
		Loop While rtnav.FindNextElement(RTELEM_TYPE_TEXTRUN)
		Call doc2.Save(False,True)
	Call session.UpdateProcessedDoc( doc )
	Set doc = collection.GetNextDocument(doc)
Wend
This error is critical for me and i don’t know why doesn’t work(Maybe the UnprocessedDocuments faults?)
Thanks in advance
Subject: Problem transfering Button LS code to Agent
You shd set your db before the line “Set collection = db.UnprocessedDocuments”.
Without setting database you cannot get the collection.
:slight_smile:
