Problem: Script lines desapear when saving.[SOLVED]
Hi there,
let’s see if this happened to somebody.
I’m writing a script(Lotus script) and when I save (Crtl+s or click on save button) the line in which I have the pointer desapears.
My english is not so good, i’ll try to explain it with other words:
The line is which the pointer is desapears, leving a blank space on it, when I save the script. In case a script error appears, the designer don’t save, then the line remains where should be.
Thanks to all.
Subject: Problem: Script lines desapear when saving.
Check the fix list. I’m pretty sure that this little ‘feature’ was a bug that was fixed in 6.5.4/6.5.5
Subject: RE: Problem: Script lines desapear when saving.
Many thanks, i’ve downloaded the c889nna.exe and looks like it works.
Thanks.
That issue ocurrs when you have some error in the code somewhere else in the form, in a field or in some other action! Not in the code where the line disappears!!
Greetings
Then I must check the rest of the form?
If I have understood : I have an error somewhere in the form, and this error efects in a script which is correct.
Tree points for Notes and its easter eggs. :frowning:
Thanks for your fast reply.
Yes , check the rest of the form, i had the same issue few days ago, i had a formula expression wrong and it deleted my lotusscript code. I went mad!
Greetings
