Problem renaming attachments
hi,
i try renaming attachments with a shared action.
First I am extracting the attachments and then I try to reattach them with Lotusscript NotesrichtextItem.EmbedObject.
This works in most cases, but some pdf’s are not reattached correctly !!! So for example in one document a pdf and jpeg are renamed correctly, but the second pdf only shows as symbol in the document and clicking gives back an error like “Element of document not found” (sorry German Error Message).
Here my Code:
okSave = False
Set itbody = doc.GetFirstItem(“Body”)
If Not itbody Is Nothing Then
attlist =itbody.EmbeddedObjects
	'Email auf Dateianhänge prüfen
	If Not Isempty(attlist) Then
		Forall attachFile In attlist
			okRemove = False
			If attachFile.Type=EMBED_ATTACHMENT Then
				strFilename = attachFile.Source
'Want rename?
			okRename = Messagebox("Möchten Sie jetzt den Anhang '" & _
strFilename & “’ umbennen?”, 3+32+0, “Anhang gefunden”)
If okRename=6 Then
					strName = attachFile.Name
					Forall i In doc.Items
						If i.Name = "$FILE"  Then
							If i.Values(0) = strFileName Then
'Input here new Name
								strNewFilename = Inputbox("Bitte den neuen Namen eingeben", "Anhang umbenennen", strFilename)
								If Lcase(strNewFilename) = Lcase(strFilename) Or strNewFilename = "" Then
									Msgbox "Abbruch: Der neue Name ist leer oder hat sich nicht geändert !"
									Exit Forall
								attachFile.ExtractFile("C:\" & strNewFilename)
								Set newEObj = itBody.EmbedObject(EMBED_ATTACHMENT, "", "C:\" & strNewFilename)
								okRemove = True
								okSave = True
								Call attachFile.Remove()
								Call i.Remove()
								Exit Forall
						End Forall
						If okRemove Then
							Kill "C:\" & strNewFilename
							okRemove = False
			End Forall
			If okSave Then
				Call doc.Save(True, True)
Code problem or type of pdf??
Any idea?
best regards
Heiner
