Problem printing doc
I have a problem to print a nsf database “document” from Lotus Client
The issue because some characters on part of line documents are non swowing
This happen only from one printer(a little bit old) on others is OK,
If I do a print screen and copy the iammge document in a word page, the print is correct
I have reinstall print driver
Any suggestion would be very apprecciated
Subject: Problem printing doc
A few ideas:
  • Put the entire document in a table with zero border
  • change your form design in some other way (add margins whatever)
  • Toss out your old printer or don’t use it
  • Use your printer settings to add a margin.
  • Preview your document over the Web and print from there instead.
  • printer issues are rare and tricky to handle when they occur.
