hi,
I totally cannot preview my XPages on the browser, every time it shows “HTTP Web Server : Item Not Found Exception”.
I would like to ask on the server side, do I need to do any setting in order to make the XPages run well?
hi,
Subject: is this a local or a server preview?
if your database is local, there are no settings to do, and you likely have a coding error in the page.
If your database is on a server, check the programmability restrictions on the security tab of your server’s server document to be sure that you have the rights to run agents and XPages.
