Problem opening view applet in popup window
I have a form that displays ‘child’ documents in an embedded view. In one of the columns I display a url link
javascript:myfunction(params);
myfunction builds a url and opens a popup window containing a view determined by the params. The url is to a form in another database. The parameters are used to compute the name of the view and the category to be displayed.
I had it ‘working’ as a button from within the child document.
If I paste the url into the browser it opens as expected.
As described above it opens the window - all the parameters are there - but no view applet:-(
Any ideas?
TIA
Gerry
Subject: Sorted
I cloned the popup to have a seperate version for each view rather than one form with a computed view. Luckily there were only 3…
