Problem Opening PPS files
Hi all,
We are having a problem in opening PPS(PowerPoint Slideshow) files from the client . The files have macro, so while opening it comes with the Security Warning to either enable/disable Macros.
But the screen hangs and until I launch eh Task manager , the application is not executed .
Now we have recently migrated to MS Office 2003 . Can it be a reason . We tested it on MS Office 2000 , and its works fine there. Also, we created an entry for PPS Files in the File Identifications and rebooted the server, but with no luck.
Can anyone help on this . It’ll be very helpful.
cheers
Tom
