All,
I have a problem when running Java agent that using native method (load library) sapjcorfc.dll. What I wanted to do is I want to connect to SAP using SAP-JCO Connector.
At the first time I executed the Java agent, it was successfully executed (I got reply from SAP). But at second time and next, it was always thrown an exception as shown bellow :
java.lang.ExceptionInInitializerError: JCO.classInitialize(): Could not load middleware layer ‘com.sap.mw.jco.rfc.MiddlewareRFC’
Native Library C:\temp\SAPConnector\sapjcorfc.dll already loaded in another classloader
at com.sap.mw.jco.JCO.<clinit>(JCO.java:565)
at JavaAgent.NotesMain(JavaAgent.java:16)
at lotus.domino.AgentBase.runNotes(Unknown Source)
at lotus.domino.NotesThread.run(NotesThread.java:208)
It’s likely that Domino doesn’t unloaded the library automatically, because the error tells that the library already loaded after first execution. I use Domino Designer6.5 and Domino Server6.5 (trial version) running on WinXP Prof. Is there any bugs in this version?
Can anyone tell me what should I do? Please, really need help.
Thanks,
Henri
