Problem obtaining Replication History via LotusScript on 64-bit OS
I am hoping that someone can help me with the problem when running a LotusScript that calls a Lotus C API and a Windows API to obtain the replication history of a domino application.
The script works fine when executed on a 32-bit or 64-bit Windows OS with a 32-bit Notes or Domino client. However, with 8.5.1 and 8.5.2, the Domino server can now be 64-bit. When the script runs on a 64-bit OS with a 64-bit Domino server, it fails.
I think the problem is with the handles that need to be passed to Windows API “RtlMoveMemory”. I am not sure what has to be changed for the 64-bit OS. According to the Domino documentation, the handles are all still 32-bit within Domino, but I think the handles need to be 64-bit for the OS.
Can anyone help?
Here is the code (it is very similar to the sample code for the replication history):
Option Public
Option Declare
Type HIST_ENTRY
RepTime As String
ServerName As String
FileName As String
Direction As String
End Type
Type TIMEDATE1
Innards0 As Long
Innards1 As Long
End Type
Type REPLHIST_SUMMARY
ReplicationTime As TIMEDATE1
AccessLevel As Integer
AccessFlags As Integer
Direction As Integer
ServerNameOffset As Long
ServerNameLength As Integer
FileNameLength As Integer
Spare1 As Long
Spare2 As Long
End Type
Declare Private Function NSFDbOpen Lib “NNOTES” Alias “NSFDbOpen” (ByVal P As LMBCS String, H As Long) As Integer
Declare Private Function NSFDbClose Lib “NNOTES” Alias “NSFDbClose” (ByVal H As Long) As Integer
Declare Private Function OSPathNetConstruct Lib “NNOTES” Alias “OSPathNetConstruct” (ByVal NullPort As Long, ByVal Server As String, ByVal File As String, ByVal PathNet As String) As Integer
Declare Private Function NSFDbGetReplHistorySummary Lib “NNOTES” Alias “NSFDbGetReplHistorySummary” (ByVal H As Long, ByVal F As Long, retSum As Long, retNum As Long) As Integer
Declare Private Function OSMemFree Lib “NNOTES” Alias “OSMemFree” (ByVal H As Long) As Integer
Declare Private Function OSLockObject Lib “NNOTES” Alias “OSLockObject” (ByVal H As Long) As Long
Declare Private Function OSUnlockObject Lib “NNOTES” Alias “OSUnlockObject” (ByVal H As Long) As Integer
Declare Private Function OSLoadString Lib “NNOTES” Alias “OSLoadString” (ByVal hModule As Long, ByVal StringCode As Integer, ByVal retBuffer As String, BufferLength As Integer) As Integer
Declare Private Sub CopyMemory Lib “kernel32” Alias “RtlMoveMemory” (pDest As REPLHIST_SUMMARY, ByVal pSource As Long, ByVal dwLength As Long)
Declare Private Sub CopyMemoryStr Lib “kernel32” Alias “RtlMoveMemory” (ByVal pDest As String, ByVal pSource As Long, ByVal dwLength As Long)
Function GetReplHistory(db As NotesDatabase, sList() As String, lEntries As Long) As Integer
Dim hDB As Long, hLock As Long, hSummary As Long
Dim nLoop As Integer, nPos As Integer
Dim sPath As String, sHold As String, sTemp As String
Dim summary As REPLHIST_SUMMARY
Dim entry() As HIST_ENTRY
Dim eTemp As HIST_ENTRY
Dim nm As NotesName
Dim i As Long
Dim j As Long
Dim tb As String
Dim dtmdt As Double
tb = Chr(9)
GetReplHistory=0
sPath=Space(1024)
On Error GoTo processError
OSPathNetConstruct 0, db.Server, db.FilePath, sPath
GetReplHistory=NSFDbOpen(sPath, hDB)
If GetReplHistory <> 0 Then GoTo alldone
GetReplHistory=NSFDbGetReplHistorySummary(hDB, 0, hSummary, lEntries)
If lEntries > 0 Then
	ReDim entry(lEntries - 1)
	hLock=OSLockObject(hSummary)
	For nLoop=0 To lEntries-1
		CopyMemory summary, hLock, LenB(summary)
		dtmdt = (summary.ReplicationTime.innards1 And &HFFFFFF) - &H24D9AB + (summary.ReplicationTime.innards0 And &HFFFFFF)/24/360000
		If Not (dtmdt < -657434 Or dtmdt > 2958465) Then
			entry(nLoop).RepTime = Format(CDat(dtmdt),"yyyy/mm/dd hh:nn:ss") & " GMT"
		Else
			entry(nLoop).RepTime=""
		Select Case summary.Direction
			Case 0
				entry(nLoop).Direction="Never Received"
			Case 1
				entry(nLoop).Direction="Send"
			Case 2
				entry(nLoop).Direction="Receive"
			Case Else
				entry(nLoop).Direction="Unknown"
		End Select
		hLock=hLock+Lenb(summary)
	Next
	sHold=""
	sTemp=String(1, 0)
	nLoop=0
	Do While nLoop < lEntries
		CopyMemoryStr sTemp, hLock, 1
		If sTemp = Chr(0) Then
			nPos=InStr(1, sHold, "!!")
			Set nm=New NotesName(Left(sHold, nPos-1))
			entry(nLoop).ServerName=nm.Abbreviated
			entry(nLoop).FileName=Right(sHold, Len(sHold)-nPos-1)
			sHold=""
			nLoop=nLoop + 1
		Else
			sHold=sHold & sTemp
		hLock = hLock + 1
	Loop
	OSUnlockObject(hSummary)
	Do
		j=0
		For i=0 To lEntries-2
			If entry(i).RepTime < entry(i+1).RepTime Then
				j=j+1
				eTemp=entry(i)
				entry(i)=entry(i+1)
				entry(i+1)=eTemp
			ElseIf entry(i).RepTime = entry(i+1).RepTime Then
				If entry(i).ServerName > entry(i+1).ServerName Then
					j=j+1
					eTemp=entry(i)
					entry(i)=entry(i+1)
					entry(i+1)=eTemp
		Next
	Loop While j > 0
	ReDim sList(lEntries-1)
		sList(nLoop)=Trim(entry(nLoop).ServerName & tb & entry(nLoop).FileName & tb & entry(nLoop).RepTime & tb & "(" & entry(nLoop).Direction & ")")
	Next
alldone:
	lEntries = 1
	ReDim sList(lEntries - 1)
	If GetReplHistory = 578 Then
		sList(0) = "No Replication History"
	Else
		sTemp = String(256, 0)
		OSLoadString 0, GetReplHistory, sTemp, 255
		sList(0) = Trim("Replication History Error:  " & sTemp)
endfunc:
On Error GoTo 0
If hLock <> 0 Then OSUnlockObject(hSummary)
If hSummary <> 0 Then OSMemFree hSummary
If hDB <> 0 Then NSFDbClose hDB
Exit Function
’ error handling routine
processError:
GetReplHistory = Err
sTemp = "Replication History Error: " & CStr(Err) & " on Line" & CStr(Erl) & ": " & Error$
lEntries = 1
sList(0) = sTemp
Resume endfunc
End Function
Subject: Perhaps a solution
I believe but I haven’t tried it that you need to double the length of all number variables in 64bit environments.
So Integer becomes long
and long becomes double
Subject: Same issue
I’m trying to retrieve the Replication History from within a schedule server agent and I’ve exactly the same issue! It works on a 32-Bits Domino server and fails on a 64-bits version… It’s seems to be related to memory offset in some way but can’t figure it out?!
Did you find a workaround finally??
Vincent.
Subject: No solution yet
I have not found a solution to this problem yet. I agree it has to do with the memory offset, but I can’t figure out how to get the 32 and 64 bit calls to match.
