Hi All, I have a pecuilar problem . When I am open a document in the view mode it is fine, but whenever open the same document in the edit mode an error comes " NSD is running " and the application terminates . Any clue as to why this happens and also the solution for there .
Regards,
Sudheer.
Subject: Problem “NSD is running”
NSD is running because something is wrong, so I’d go to the form and remark QueryOpen event, PostOpen event, then Field Formulas… until I could find the bug.
I hope this may help u.
All the best.
Subject: Problem “NSD is running” - solution
I had the same problem on a client’s pc and i just uninstalled and installed version 6.5.2 and it worked
There must be something that u’ve written in the Form events like the PostOpen , Initialize events or on the Fields …Go thru the Form with a fine comb.
Khushi
