Problem migrating data with dus
Hello, i’m tring to migrate user from exchange 2003 to domino 8.5 with dus.
The mailbox in echange is italian and must be in italian in domino.
If i do the migration with domino dus on admin8.5 the data wasn’t migrate correctly (in calendar no data and the mail have flag private) and the contact was ok
If i make migration with dus on admin 6.02cf1 data was migrate ok but not the contact ($contact was empty)
any suggestion? i must find admin client in italian? i’m not sure it exist
and unread marks? any change to mantain?
regards
Subject: From Exchange DUS support
There have been a significant number of feature changes between R6.0.2 and R8.5.
Customer should use Italian admin client to migrate and the locale should be set as Italian too.
TN 1194499 :Migration tools should match the language version of the data being migrated
Subject: yes
Thanks you are right, the problem was italian admin doesn’t exist…
i’ve open a pmr and i’m on support…
regards
