I’m having a bit of a problem loading LDAP on a 6.0.1 CF1 French language pack server. I tried to recreate the schema but unfortunately, it doesn’t even get there. The error seems to be coming from somewhere else. I haven’t found anything on the forums. I can assure you this is a server machine.
We are running the Windows 2003 Server and the server is running perfectly except for the LDAP part.
I’m not sure what I should check (English is not ma native language, sorry!). The server have his fixed IP address and communicate with many other servers.
I’ll be upgrading the server to Domino 6.5.3 in the coming hours. I’ll see if that can take care of the problem.
We just upgraded our server to 6.5.3 with french language pack and everything is working fine. Guess I’ll never understand why it did this. Anyways, I thank you very much for your help.
Thank for this resolution. The KitType=2 is very much effective. Some how when I upgraded the admin client to 7.0.2, the KitType was replaced by 1 and I just changed it back to 2 and all working fine now. Bottomline, have a backup of all necessary files (names.nsf, notes.ini, and .NTFs) before performing any changes on your Domino server.
