Problem installing Language Pack - Domino not there
When attempting to install Language Packs on Domino 6.5.2 running on Windows NT 4 the installation stops with a message saying that there are no indications of Domino being installed in the directory. The correct directory has been selected.
Has anyone got any idea how to resolve this issue?
The server has been upgraded from 5.0.12 to 6.5.2 and previously from 4.6.x.
Subject: Problem installing Language Pack - Domino not there
Have you got a pubnames.ntf in your data subdirectory?
Rufus.
Subject: RE: Problem installing Language Pack - Domino not there
Cheers Rufus. No there is no pubnames.ntf! I forgot that a number of standard templates are manually removed from the data directory after installation. I will copy them back and give it another go.
Thanks,
Calvin.
You’re welcome - let us know if it does resolve it.
Rufus.
Yes, putting pubnames.nsf back in the data directory fixed the problem.
Thanks,
Calvin.
