Problem installing Domino on Solaris blade T6300
We run Domino 8.0.0 on Solaris 10 on a Sun V240 with 2 UltraSparc III1 @ 1.5 GHz. We are trying to migrate to a T6300 blade with 1 UltraSparc T1 - 6 cores with 16 GB memory.No luck so far, we get plenty of segmentation faults and core-dumps. We tried 8.0.0 and 8.0.1 with the same result, also tried editing the notes.ini with the memory parameters, also no luck.
$ /opt/ibm/lotus/bin/server
Lotus Domino (r) Server, Release 8.0, August 02, 2007
Copyright (c) IBM Corporation 1987, 2007. All Rights Reserved.
07/16/2008 13:24:41 Event Monitor started
07/16/2008 13:24:41 Warning: All Domino Domain Monitoring probes are disabled resulting in the loss of valuable diagnostic information. Please configure DDM probes in events4.nsf. Assess DDM reports in ddm.nsf.
07/16/2008 13:24:43 Searching Server document for security lists
07/16/2008 13:24:43 Server started on physical node dxldom01
  • Child Terminated from signal 11
7/16/2008 13:24:45 Running NSD
NSD is in progress …
07/16/2008 13:21:38 Event Monitor started
07/16/2008 13:21:38 Warning: All Domino Domain Monitoring probes are disabled resulting in the loss of valuable diagnostic information. Please configure DDM probes in events4.nsf. Assess DDM reports in ddm.nsf.
/opt/ibm/lotus/bin/server[1182]: 966 Segmentation Fault(coredump)
Any ideas??
Regards
Martijn
Subject: Solved - Installing Domino 8 on Solaris 10
After talking to support, there is a known issue with the latest kernel patch from Sun and Domino 8.0.0 and 8.0.1.here’s the response from IBM:
I was able to identify your issue. It is currently investigated under SPR # SDSS7GFSGT: “Domino server crash on startup after Solaris 10 patch 137111-01 or 137111 -02 is installed.”
There is no fix yet, only a workaround: Uninstall the Solaris patch 137111.
I also tried installing the patch 137111-03, but the issue is not resolved.
After uninstalling patch 137111 Domino runs fine.
Regards
Martijn
Subject: RE: Installing Domino 8 on Solaris 10
We ran into the same issue with the kernel patch on a new install here. The IBM tech that I worked with has opened a problem report with Sun so we’ll see where that goes.
Subject: RE: Problem installing Domino on Solaris
We have also that problem with Domino 6.5.6PF1SUN Support told us to try 137111-02 there should the problem be fixed.
I tried installing the patch 137111-04 yesterday, but the issue is not resolved.
Direct after try to start the Domino Server it runs in the NSD.
I’ll reopen my Case by SUN and IBM now.
Regards
Lutz Risse
Subject: Solaris 10 kernel 138888-01
I also had this problem but I’m running Update 5 of Solaris 10. Within the latest patch cluster from Jan 2009 Kernel release 138888-01 is bundled. I just confirmed this kernel plays nice with domino and does not provide the nice BUS core dump.
