Problem initializing an array of NotesViewNavigators
Hello, all.
I am having trouble initializing an array of NotesViewNavigators. When I inspect the initialization routine in the LotusScript debugger, when viewNavArr(1) is initialized, the value for viewNavArr(0) disappears; when viewNavArr(2) is initialized, viewNavArr(1) disappears, and so on. Is this a LotusScript limitation, or do I have a bug?
Thanks,
Brandon.
' Set up the views that we are going to use for our report.
Dim viewNames( 0 To 4 ) As String
Dim viewRoot As String
viewRoot = "Data\Hourly Data\By Server\"
viewNames( 0 ) = viewRoot + "Last 24 Hours"
viewNames( 1 ) = viewRoot + "Last 7 Days\By Hour of Day"
viewNames( 2 ) = viewRoot + "Last 7 Days\Show All"
viewNames( 3 ) = viewRoot + "Last 30 Days\By Hour Of Day"
viewNames( 4 ) = viewRoot + "Last 30 Days\Show All"
' Get the navigators for each of these views.  We need the
' navigators so we can step through the views to grab the
' entries that have our totals on them.
Dim temp1 As NotesView
Dim viewNavArr( 0 To 4 ) As NotesViewNavigator
For i = 0 To 4
	Set temp1 = dbLocal.GetView( viewNames( i ) )
	Set viewNavArr( i ) = temp1.CreateViewNav
Next
Subject: Problem initializing an array of NotesViewNavigators
Apparently the problem was in generating the views while within the loop. If I move the .GetView statement out of the loop, the NotesViewNavigators are created just as they should be.
Thanks,
Brandon.
Subject: Re: Problem initializing an array of NotesViewNavigators
Just FYI - most Domino objects work that way. If you have an object reference that is used to obtain another and then lose scope of that reference usually your other derived handles are lost as well.
