Hi All.
I am facing problem in XML Dblookup…
Can any one pls help me in this matter. ?
Becozwhen lookup is happening it is getting refresh each time.
Its very urgent.
Hi All.
Its very urgent.
Subject: Problem in XML DBlookup…
I have never experienced any refresh-related problem with it, but posting one our XML dblookup function for reference, maybe it would help:
function dbLookup(server,path,view,key,column)
xmlDoc = new ActiveXObject("Microsoft.XMLDOM");
xmlDoc.async = false;
var pos=0;
currURL = (document.location.href).toLowerCase();
if (trim(server) == "")
pos = currURL.indexOf('://');
if (pos < 0 )
server = "http://11.22.33.44" // PUT YOUR SERVERNAME HERE
else
pos += 3;
pos = currURL.indexOf('/', pos);
server = currURL.substring(0, pos)
if( trim(path) == "" )
if( pos > 0 )
newPos = currURL.indexOf('.nsf',pos);
if (newPos > 0)
path = currURL.substring(pos+1,newPos+4)
//Javascript index starts at 0, so need to decrement the column by -1
if( !isNaN(column) )
column -= 1;
vurl = trim(server)+"/"+trim(path)+"/"+view+"?readviewentries&login=1&count=9999&startkey="+key;
xmlDoc.load(vurl);
if (xmlDoc.documentElement == undefined)
return("")
nodes = xmlDoc.documentElement.childNodes;
temp = new Array(nodes.length);
var j = 0;
for (var i = 0; i < nodes.length; i++)
if(nodes.item(i).childNodes.item(0).text==key)
temp[j] = nodes.item(i).childNodes.item(column).text;
j++;
else
break;
var results = ""
for (var i = 0; i < j; i++)
if (i==0)
results = temp[i];
else
results = results + ", " + temp[i];
return(results);
} //End of dbLookup
function trim(sStr)
var iI = 0;
var iJ = 0;
var iTam = 0;
var sAux = "";
iTam = sStr.length;
if(iTam==0) return(sStr);
for(iI=0; iI<iTam; iI++)
if(sStr.charAt(iI)!=' ') break;
if(iI >= iTam) return("");
for(iJ=iTam - 1; iJ>=0; iJ--)
if(sStr.charAt(iJ)!=' ') break;
return(sStr.substring(iI,iJ+1));
} //End of trim
