Problem in Save & Complete on web
Hi all,
I meet a problem again on web access.
Let me to explain my case slowly.
I have created a form and implmented a button to save it by @Command([FileSave]); .
However, I need it to trigger a routing after save just like the orignal “Save & complete” button. How can I enable it?
I try to using included the orignal OS workflow web information subform. But the “save & complete” button does not work. The screen just flash once and nothing changed after press the “save & complete” button.
Anyone have any idea on this issue?
please help , thx.
Regards,
Jam
Subject: Problem in Save & Complete on web
Hi,You can use $$return field on your form for routing after saving or you also call an agent for routing in webquerysave.
I hope this helps…
Subject: RE: Problem in Save & Complete on web
I assume you are using domino.workflow because you are talking about the OS workflow web information subform.Just one tip DON’T enable ‘generate HTML for all fields’ on your form as this wiil break the javascript code.
Oh, it work now just after I have disabled the “auto generate HTML” checkbox.Thank you.
well, true…I suppose I was post to the wrong forum…sorry
Thank you for your advise.But can you describe more as I am a very fresh comer on Lotus Notes.
Should I call “OS Reroute Binder 32Bit” for the routing?
