Problem in removing Attachment
Hi all,I have lot of RTF fields in my odc, I would like to extract the atatchment and remove the atachments only on certain RTF field.
I created setting doc and mention the RTF fields name where i would liek to remove attachment. It works fine, but the problem is If i have same attachment in 2 different RTF or on the same RTF,then my code is not working fine, it some times remove the attachment wrongly. I noticed that if i do same attachment in a doc, notes internaly change the name for any one of the atatchment. How to over come this.
Below is my code.some declaration and soem part of code i removed for readablity purpose.
Set rtitem = doc.getfirstitem(t.name)
Set nav = rtitem.createnavigator
attachavailable = nav.findfirstelement(RTELEM_TYPE_FILEATTACHMENT)
If attachavailable = True Then
Forall obj In rtitem.embeddedobjects
If obj.type = EMBED_ATTACHMENT And attachavailable= True Then
object = rtitem.embeddedobjects
If Not Isempty(object) Then
Forall o In rtitem.embeddedobjects
If o.type = EMBED_ATTACHMENT Then
Set object = rtitem.GetEmbeddedObject( o.source )
Call o.extractfile(localpath) Forall tt In doc.Items
If tt.name=“$FILE” Then
Set ob = doc.GetAttachment(tt.values(0))
If ((ob.name = o.name) And (fsizeforrem = ob.filesize))Then
Call ob.remove
Call tt.remove
Exit Forall
regds
soma
