Hi all, I am using the following code, it is extracting the files but the files are not removed from the doc, instead it is again attaching at the bottom of the doc, any idea?Forall o In rtitem.embeddedobjects
If o.type = EMBED_ATTACHMENT Then
Call o.remove
call doc.save(true,false)
End Forall
regds
soma
