Problem in Notes Java Agent when converting from XML to HTML using XSL
I am trying to get an HTML output by converting a XML file using a XSL file.
When I use java agent and use :
XSLProcessor xp = new XSLProcessor(new XMLParserLiaisonDefault());
XSLTInputSource xmlSource = new XSLTInputSource(xmlFilename);
XSLTInputSource xslSheet = new XSLTInputSource(xslFilename);
XSLTResultTarget result = new XSLTResultTarget(htmlFilename);
xp.process(xmlSource, xslSheet, result);
The conversion does not happen correctly. I am using “count” function in the XSL which does not seem to work.
If I write a Lotus Script agent with the new classes of R6, the conversion works just fine.
The XML and XSL are correct because I have verified it by opening the XML in Internet Explorer and let IE do the conversions.
Does anyone know if there is some problem with the java xml-xsl conversions or if there is an alternative that I can use in my java code
Any help is greatly appreciated.
Thank You
Regards,
Bharat Kothari
Subject: Problem in Notes Java Agent when converting from XML to HTML using XSL
Please note the correction to the code snippet :
XSLProcessor xp = new XSLProcessor(new XML4JLiaison4dom());
Regards,
Bharat kothari
