Problem in login using aliases
Hi,I have a problem, a person document in the domino directory contains 3 aliases(UserName).
User is being able to login to the web-based application using the first two aliases without any problem, but when he tries to login using third alias, he is denied access.
Can you help me out why this is happening.
Thnx in advance.
Regards
Prashant
Subject: Problem in login using aliases
Can you put those aliases? Mainly problem is with national characters.
Subject: RE: Problem in login using aliases
the uernames/aliases mentioned in the person document of the user are as below:-----------------------------
Lia yang/Research
Lia yang
XJ03535
user is being able to login using first two aliases/usernames but “XJ03535” not working
i hv also checked that this username “XJ03535” is unique in the domino directory.
