i have the following code which is used to dispaly a dialog box with some value, i choose any value , its working fine… but the other columns is not letting me edit ( i don’t want dialog box for other column ) to put some new value…
how can i club the dialogbox for some columns and the way we nomally edit for some columns.
code as of Now… working well with Dialoglist…
Sub Inviewedit(Source As Notesuiview, Requesttype As Integer, Colprogname As Variant, Columnvalue As Variant, Continue As Variant)
REM Define constants for request types
Const QUERY_REQUEST = 1
Const VALIDATE_REQUEST = 2
Const SAVE_REQUEST = 3
Const NEWENTRY_REQUEST = 4
REM Define variables
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim caret As String
REM Create Dialog Box for given column field
Dim values() As String
Dim value As String
If RequestType = QUERY_REQUEST And ColProgName(0) = "Test1" Then
Redim values(5) As String
values(0) = "-DELETE-"
values(1) = "Document Store"
values(2) = "Discussion Database"
values(3) = "Data Store"
values(4) = "Process Support Database"
values(5) = "Group Mail Box"
value = ws.Prompt(PROMPT_OKCANCELLIST,"SELECT","Select a Type","",values)
If RequestType = QUERY_REQUEST And ColProgName(0) = "Test2" Then
Redim values(3) As String
values(1) = "Simple Database"
values(2) = "Simple Workflow"
values(3) = "Complex Workflow"
value = ws.Prompt(PROMPT_OKCANCELLIST,"SELECT","Select a Category","",values)
REM Get the CaretNoteID - exit if it does not point to a document
caret = Source.CaretNoteID
If caret = "0" Then Exit Sub
REM Get the current database and document
Set db = Source.View.Parent
Set doc = db.GetDocumentByID(caret)
If doc Is Nothing Then Exit Sub
REM Select the request type
Select Case RequestType
Case QUERY_REQUEST
REM Check value and save doc with new value if valid
continue=False
If value = "" Then Exit Sub
If value = "-DELETE-" Then value =""
Call doc.ReplaceItemValue(Colprogname(0), value)
Call doc.Save(True, False)
Call ws.ViewRefresh
Case VALIDATE_REQUEST
REM Validate Changes
Case SAVE_REQUEST
REM Write the edited column view entries back to the document
Case NEWENTRY_REQUEST
REM Create document and create “Form” item
End Select
thanks
Rupesh
