Problem in Inview edit for Views --- Urgent!
Hi Everybody,A document with a text field x has a value 5.
This is selected in a view. There is validation in the the script to trap invalid values.
When view column is edited in notes and the value is modified to 5&. The Invalid value message is shown desired but thereafter notes
throws an error message “Error validating column value”.
Is there any solution to this problem ?
Satyajit
The inview edit script is as below
Sub Inviewedit(Source As Notesuiview, Requesttype As Integer, Colprogname As Variant, Columnvalue As Variant, Continue As Variant)
Const QUERY_REQUEST = 1
Const VALIDATE_REQUEST = 2
Const SAVE_REQUEST = 3
Const NEWENTRY_REQUEST = 4
REM Define variables
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim caret As String
REM Get the CaretNoteID - exit if it does not point at a document
caret = Source.CaretNoteID
If caret = "0" Then Exit Sub
REM Get the current database and document
Set db = Source.View.Parent
Set doc = db.GetDocumentByID(caret)
REM Select the request type
Select Case Requesttype
Case QUERY_REQUEST
REM Reserved - do not use in Release 6.0
Case VALIDATE_REQUEST
	Msgbox "Columnvalue(0)   "&Columnvalue(0)
REM Cause validation error if user tries to exit column with no value
	If Instr(Columnvalue(0)," ") Then
		Continue = False
		Msgbox "with space"
	If Instr(Columnvalue(0),"&") Then
		Continue = False
		Msgbox "with&"
		Exit Sub
Case SAVE_REQUEST
REM Write the edited column view entries back to the document
	For i = 0 To Ubound(Colprogname)
		Call doc.ReplaceItemValue(Colprogname(i), Columnvalue(i))
	Next
REM Save(force, createResponse, markRead)
	Call doc.Save(True, True, True)
Case NEWENTRY_REQUEST
REM Create document and create “Form” item
REM Write column values to the new document
	Set doc = New NotesDocument(db)
	Call doc.ReplaceItemValue("Form", "Test")
	Next
End Select
