Problem in iNotes Sync Manager
Hi,I am facing a problem with the Lotus iNotes Sync Manager. I have a database XYZ which is created using a previously existing database ABC. The name of ABC was changed to XYZ.
The installation of the Lotus iNotes Sync Manager works well, but when the sync tries to take the dbase offline, there are 2 problems:
  1. In the subscription title in the sync manager, the previous database name i.e., ABC is displayed.
  2. In the sync status column it says: Active:File does not exist
Can someone help me with this? How can I change the Subscription Title? And why does the status show that message?
Thank you in advance.
-Nikita.
