I will brief my problem. There are 2 databases “A” and “B”. B database is deleted from server. Now I am working on A database. There are some fields which retreive data from B database. There are two fields getting data from B database views.
I have created two new views and two forms similar to the B database, changed the dblookup formula to current server. but still I am not getting the data.
Yes. Initially the problem was “not able to find path to server” then after some modifications the error is “Entry not found in index or view’s index” . I have indexed properly
