I have made a profile document with three fields1. Background (Color Field)
Text (Color Field)
$ColorInUse (Formula Field) with formula
Background:Text
In the view, extreme left column is hidden, with ‘Use value as color’ checked and with programatic name ‘$ColorInUse’ and with profile name given.
But its not working.
Anyone with a clue for it???
Subject: Problem in column property ‘Use value as color’
I faced the same problem and found out the following:
- The “Formula” field, $ColorInUse in your case, needs to be a regular text field. The value of this field needs to be a string evaluating to a formula
e.g. “Red := 255:0:0; Black := 0:0:0; @If(Status ="Draft";"”+ColorField1+“"; Status="Final";"”+ColorField2+“"; Black:Red)”
- The value of the color column ($ColorInUse) in the view needs to be @UserName. Any other formula will result in a view showing only replication of save conflicts.
I hope this helps.
