Subject: problem for translating C function in lotuscript
GlobalUnlock: This function is provided only for compatibility with 16-bit versions of Windows.
are you programming for Windows 3.x?
plus, to get a ptr to a buffer, in 16bits Windows, you need to GlobalLock the handle, use it, and then only GlobalUnlock it (before freeing it)
but I dont see how you could easily use the pointer in LotusScript… the best solution is actually to write the core in ‘C’ and provide simple functions to be called from LotusScript, as was advised.
I think (but I’m no expert,too) that you have to :write a program in c externally, which does this stuff for you (build it to a dll). There the above function can be called.
But you have to define a function which can be used by Lotusscript as sort of interface; to this function you maybe just give the path to the bmp-file as a string or something like that. Then you put your new dll into your LotusScript code, call the “interface” - function and there you go.
