Problem exporting foreign character with DXLExporter
Hello,I want to export Notes Documents with foreign characters as “ü” for example, with the Java DxlExporter class. Problem is that the Exporter converts these characters to signs like “³”. Using the Lotus script Exporter I did not get these problems. Can anybody help ?
CU Martin
Subject: Problem exporting foreign character with DXLExporter
Hi again,sorry I just found the solution in this forum. You have to do “stream.open(filename, “UTF-8”)”
Martin
