I’d be interested to hear if anyone else has run into this issue. I have an Domino app that’s available to both Notes & Web users, and it has several forms that use embedded views that point to views in other databases. On servers running 6.5.1 this functionality has worked fine from both a Notes client or a web client (embedded views are set for Java Applet). I recently noticed that on our 6.5.4 server, that when accessed from a Web client, the embedded views that point to another database do not display at all. I’ve since tried this on several other 6.5.4 servers with the same results. This appears to be a bug introduced in 6.5.4. Has anyone else experienced this?
Subject: SPR# JGON685T7D
Well, I’ve answered my own question after more research. Found the below post in Technotes:
In Summary, it says this is a bug that was introduced in 6.5.3 and the workaround is to set the “anonymous” ACL entry to “Reader” instead of “No Access”. I’ve done this on the copy on my 6.5.4 server and it solved the problem, but it’s certainly a security concern!
The other workaround that they don’t mention is to not upgrade past these versions, or, as will happen in my case, roll back to these versions.
