Problem deleting folders
Hello,
I have a problem in deleting the folders from my lotus notes(8.2).
When I go in tools, I do not have the folder options (the line is not there) and when I do a right click on the folder, I can not click on “remove” or “design” or “rename”.
Thoughwhen I go to my archive, I have the folder options.
Thx in advance if somebody can help me
Subject: Maintenance
Try running fixup -F, updall -R, and compact -c -i on your mail file. If that doesn’t fix it, try a refresh design.
