Problem Create Replica with AdminP
Hi
I have Lotus Domino 6.01 CF1 and have a problem with Creating Replicas.
The message is Title: Administration Requests (R5.0) File name: admin4.nsf; Name: FK01/Handels; Error: Insufficient disk space
If I have filled in the path i e e:\lotus\domino\data\test\test.nsf the message is Received the status – Remote pathname must be relative to Data Directory – trying to create e:\lotus\domino\data\test\Version 6 Test.nsf on in01/Handels; defaulting to an older replica creation technique.
But the older technice also fails with same error.
The only way to create a replica is to create them one by one in the Notes client. That works.
Is it a bug or is that some configuration errors.
The server work fine for one year with Domino 5.0.11
Subject: Problem Create Replica with AdminP
Tord,
some thoughts:
  • make sure you really have sufficient diskspace on both source and target server.
  • if you use the destination path field, you only need to type (in your case) "test" in front of the target filename, without leading backslash and, as said, relative to the data directory (no e:.…).
  • make sure the source server is in the field “Create Databases” in the server doc of the target server.
Regards,
Oliver
Subject: RE: Problem Create Replica with AdminP
This is a reported bug, http://www-1.ibm.com/support/docview.wss?rs=463&context=SSKTMJ&q=adminp&uid=swg21095559&loc=en_US&cs=utf-8&lang=en
The problem is when using W2000 server and not using english as the default language on the server. This causes the error. Fix is coming in 6.02
OK Thanks
Its a big bug for me. But I hope that release 6.0.2 have a solution.
