Problem Copying RichText Item
Hello;I am creating a document(uicon) using another document(currentdoc). I take some fields from currentdoc and set them in uicon using an agent.I have a field named DM_PieceJointeSolution which is of type ‘Richtext’,i have to take whatever is there and put it in the CNS_PieceJointeSolution field.
Earlier i used to do it like >>>See snippet of codes.
Set currentdoc=uidoc.document
Set uicon = ws.ComposeDocument(nomserverconn,nombaseconn,"CNS",,,True)
Set docconn=uicon.Document
docconn.SaveOptions="1"
Call uicon.FieldSetText("Doc_EDP", ensemble)
Call uicon.FieldSetText("Classeur",classeur)
Call uidoc.GoToField( "DM_PieceJointeSolution" )
Call uidoc.SelectAll
Call uidoc.Copy
Call uicon.GoToField( "CNS_PieceJointeSolution" )
Call uicon.Paste
Call uicon.Refresh
Call uicon.Save
But then the user complained that if he make a ‘print screen’ or copy something before using the agent, whatever he has copied get pasted in the “CNS_PieceJointeSolution” instead of what is in the “DM_PieceJointeSolution”!!!
So I thought of changing the code to this:
Dim rtitemA As Variant
Dim rtitemB As Variant
Set rtitemA = currentdoc.GetFirstItem( “DM_PieceJointeSolution” )
Set rtitemB = docconn.GetFirstItem( “CNS_PieceJointeSolution” )
If ( rtitemA.Type = RICHTEXT And rtitemB.Type = RICHTEXT ) Then
Call rtitemB.AppendRTItem( rtitemA )
end if
Now its not doing anything!!!Whether it has smething in “DM_PieceJointeSolution” or not,it just doesnt do anything.
Can please someone tell me how to do this???
Thanks.
Subject: Problem Copying RichText Item
Your second code is the right approach, but you need to note that rich-text items may not be accessible until you have done a save. Also, “If ( rtitemA.Type = RICHTEXT And rtitemB.Type = RICHTEXT )” will always fail unless rtitemB has already been populated.
If the doc can’t be saved immediately before the code you have written, then you should do an “artificial” save (set SaveOptions = “0”, save it, then get it back), something like this
Set note = uidoc.Document
	note.SaveOptions = "0"
	Call uidoc.Close(True)
	Set uidocNew = ws.EditDocument(True, note, , , , True)
Hope this helps
