Problem - Collection of documents between 2 dates
Hi
Can someone save my day or at least guide me in the correct direction please?
I have a view named (DO) which contains an asorted column with lots of dates in it.
Basically, from my created action button on my named (TR) folder, I am requesting the user to input 2 different dates from 2 input boxes.
I then want to gather these documents between the two dates & put them in the folder (TR).
My problem is getting the between dates into 1 collection.
So far my code looks like :
Dim ws As New notesuiworkspace
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim view As NotesView
Dim dc As NotesDocumentCollection
Dim vc As NotesViewEntryCollection
'Remove all previous docs from the view before searching.
Set view = db.GetView(“TR”)
Set vc = view.AllEntries
If vc.count > 0 Then
response = Messagebox(“Starting a new search will remove the results from the previous search.”+Chr(10)+_
	"Do you wish to continue?",36,"Outstanding Replies Search")
If response = 6 Then 'Yes
Print “General - Removing previous search results…”
Call vc.RemoveAllFromFolder( “TR” )
If response = 7 Then 'No
Continue = False
Set view = db.GetView("DO")
'Get the first input date
response = Inputbox (“Please enter the first date of your search. Please enter the format of DD/MM/YYYY”, “Search Targets”)
'Ensure inputted date is correct format
response2 = Cdat(Format(response,“dd/mm/yyyy”))
If response2 = “” Then
Exit Sub
'Get the second input date
endresponse = Inputbox (“Please enter the second date of your search. Please enter the format of DD/MM/YYYY”, “Search Targets”)
endresponse2 = Cdat(Format(endresponse,“dd/mm/yyyy”))
If endresponse2 = “” Then
Exit Sub
‘’'This is where I am having trouble !!!
query$ = ""
If endresponse2 > response2 Then
If query$ = “” Then
query$ = addtoquery$
Else
	query$ = query$ + " ACCRUE "+ addtoquery$
'Get All documents with those dates
& put in folder TR
Call vc.FTSearch(query$,0)
Set dc = view.GetAllDocumentsByKey(query$, False)
If dc.count = 0 Then
	Messagebox "The system has found no cases of outstanding replies dating "+response, 64, "Search"
	Exit Sub
'Cycle through documents, copying to archive database and then removing from live database
Set doc = dc.getfirstdocument
'variables to track progress in print bar
total = dc.count
current = 1
archived = 0
While Not (doc Is Nothing)
	Set doc1 = dc.getnextdocument(doc)
	percentcomplete = current*100/total
Call dc.PutAllInFolder( “TR” )
		'Remove from live database
		'Call doc.Remove(True)
	archived = archived + 1
'	End If
	Set doc = doc1
	current = current + 1
Wend
Print "Searching complete - please wait while the view is refreshed ... (this can take upto 30 minutes)"
'Refresh view at end (This can take a while if a large number of documents have been moved)
Call ws.viewrefresh
Print "Searching complete - thank you for waiting"
If archived > 0 Then
	Messagebox "The system found "+Cstr(total)+" cases that had outstanding replies of "+DateOpened+"."+_
	Chr(10)+" .",64,"Search Replies"
’ Wend
Subject: Query String
The following query will retrieve documents between dates you specify. Note that response$ and response2$ are strings, not dates.
"[NameOfYourDateField] <= " & response$ & " AND [NameOfYourDateField] >= " & response2$
(I’d recommend you use a form to collect the search parameters rather than popping up those input boxes.)
Subject: I have a solution
As lawrence mentioned use form to do such type of task.
Create three fields on form.
  1. FirstDate
  2. secondDate
  3. Query
First two fields take two dates to find the documents between them.
Third field …make it computed …write formula so that we can use it as view selection formula for folder.
Then write code on “Search” button using value of Query field as view selection formula and finally refresh the folder. or rebuild the view(folder).
it is so simple. try…!!
Subject: Problem - Collection of documents between 2 dates.
Look at Designer help for NotesDateTime.TimeDifference method.
